NI Package Manager (NIPM)
apt package size error
Ubuntu 22.04 doing "sudo apt update" I get the following package error. Which has persisted for a while. Have tried "apt purge" and "apt clean" commands without success
Err:10 https://download.ni.com/ni-linux-desktop/stream/deb/ni/jammy jammy/ni i386 Packages
Fetched 232 kB in 1s (174 kB/s)
Reading package lists... Done
E: Failed to fetch https://download.ni.com/ni-linux-desktop/stream/deb/ni/jammy/dists/jammy/ni/binary-amd64/Packages.gz File has unexpected size (89020 != 89369). Mirror sync in progress? [IP: 104.17.118.104 443]
Hashes of expected file:
- Filesize:89369 [weak]
- SHA256:ccd8400dec853e1a40d67236ce01b134020703a27875bbe975dc32bef08e64bb
- SHA1:deeac0e02f630fab6bdec9d693c2ddf6e1b8de42 [weak]
- MD5Sum:3b25ced31ae0ea5a9b2b496daedf37d6 [weak]
Release file created at: Fri, 05 Apr 2024 01:08:30 +0000
E: Failed to fetch https://download.ni.com/ni-linux-desktop/stream/deb/ni/jammy/dists/jammy/ni/binary-i386/Packages.gz
(873 Views)
Ironically, this has now resolved itself 🙂
(864 Views)
I am facing a similar issue. Not sure why this still appears
E: Failed to fetch https://download.ni.com/ni-linux-desktop/stream/deb/ni/jammy/dists/jammy/ni/binary-i386/Packages.gz File has unexpected size (27897 != 27986). Mirror sync in progress? [IP: ....]
- Filesize:27986 [weak]
- SHA256:034d9698ab8bce3bdc798dd225bb2b12b077c43da8a5a94f6aea59e47ba07794
- SHA1:df0d15ba2f433ded079b0f9814014a5456beb545 [weak]
- MD5Sum:5467a797dae7c4319eb6aad7d3684454 [weak]
I tried reinstalling the RIO modules as well as the usrp-host package, cleaned apt sources (including explicitly removing and refetching /etc/apt/sources.list.d), and have retried over the span of a few hours.
(799 Views)
Hello Everyone,
Does anyone have a fix for this issue or we just hope that it gets resolved on it own and not use any NI-packages till then. As I'm not able to install any of the NI packages (even from old fetched repository, as I this is first time I'm setting up ni repository).
Here are the errors I get,Err:7 https://download.ni.com/ni-linux-desktop/stream/deb/ni/jammy jammy/ni i386 Packages
File has unexpected size (27940 != 27986). Mirror sync in progress? [IP: xxx.xxx.xxx.xxx]
(628 Views)
I am also seeing these errors when trying to install the stream version of the NI drivers in Ubuntu (22.04).  Anything from NI on when this will be fixed?
(592 Views)
The file at https://download.ni.com/ni-linux-desktop/stream/deb/ni/jammy/dists/jammy/ni/binary-i386/Packages.gz has been updated to the latest version, but the previous version is still cached in /var/lib/apt/lists/, leading to the mismatch error. Please try running the following commands to clear and update the cache.
sudo rm /var/lib/apt/lists/*ni-linux-desktop*
sudo apt-get update
(561 Views)
