NI TestStand Idea Exchange
Mathieu_R.
Expose SeparatorChar property in NI_NewCsvFileInputRecordStream configuration pane
Status: New
CSV Input Stream allow to parse CSV files to input data into a Stream Loop for instance. By default, the separator is a comma (,). I use a non english version of Excel to edit a CSV file, and every CSV format write a semi-colon as separator (;):
A;0;0;2
A;10;30000;5
A;20;15;7
B;75;42;1
B;100;12;0
Using an expression, I am able to dynamically (at run-time) change the property SeparatorChar:
Locals.MyInputStream.AsCsvFileInputRecordStream.SeparatorChar = ";"
I think it could be more convenient to have a direct access to this parameter in the configuration pane, allowing also to check the content of the file  before execution with Parse Record Prototype funtions.
