I'm working extensively with LabVIEW VIs and Test Stand, and one of the most helpful features existing is the ability to configure a TestStand type to pass its data to and from a LabVIEW Cluster.
I think a great way to expand upon this would be to allow the developer to override specific variables within the LabVIEW cluster.
For instance, say I have defined a TestStand type with 5 total variables, all of which may pass to a LabVIEW cluster. If my LabVIEW cluster has at least the same number and type of variables, then this cluster passing has no issue.
However, if my LabVIEW cluster has 6 variables, then the TestStand type can only account for its defined five variables, and I am effectively locked out from the sixth variable. I cannot edit the sixth variable, nor can I assign it a default value (see Ex1_broken.PNG)
This wouldn't cause an issue if I could override specific variables within the cluster passing. That is to say, if I were given access to that sixth variable from the example, then I could assign it to a local variable. The other five variables would still be satisfied by the TestStand type, and no errors should be generated by the step. (see Ex1_fixed.PNG for what I envision this to look like)
