01-29-2021 03:55 PM
CTD has changed from multiple choices to a 4-hour coding format since April 2020. I hope this post opens up the discussion of preparation tips for the exam, and I will share mine first. See the attachment.
First of all, please refer to the official site for the exam guideline and sample exam:
https://education.ni.com/badges/resources/1259/certified-teststand-developer-ctd
Hope it helps!
03-25-2021 08:35 AM
I will take the test this year and I am trying to find all the information as possible. Thank you for your tips.
03-27-2021 10:57 PM
First of all, please refer to the official site for the exam guideline and sample exam:https://education.ni.com/badges/resources/1259/certified-teststand-developer-ctd
Hope it helps!
I recommend you all download the PDF from @hongcc1 and read it carefully. Very well done!!!
04-13-2021 07:44 PM
Hi, I have tried answering the given Sample Exam but I've been having problems regarding the error handling part when the test fixture is not initialized properly.
Could you help me with this part?
I tried looking at the solution but there was no error handling in the sequence.
Thank you!
11-11-2021 07:10 AM
Did any one reply to this message?
11-13-2021 03:37 AM
If referring to the solution, it's also not clear how this is implemented. Just from my guess, it could be implemented this way:
This is how the report will look like when error:
Anyway, I am not sure if this is correct. In real practical application, I think the Additional Result Step is a redundant thing to do since the error message will be recorded when the Setup step has an error. If I must not prompt any dialog, then choose to Ignore Run-time Error at the step, force SequenceFailed to true, and then jump to the end of the sequence. This code is just for your reference. Hope it helps.
02-13-2022 08:16 AM
Hi Guys, I meet one problem when I try to practice sample exam. After setup dll file and set code module in search folder, solution sequence can't be executed. After click run "main sequence", error will report as attached file. Is there any point I don't set correctly?
02-02-2024 12:01 AM
can you help me?
the zip file location should select where?
The NI :
“Our Grading Team reviewed your CTD exam files and we regret to inform you that there was not any exam submission to grade in the folder labeled Exam on the virtual machine.“”
06-11-2024 01:33 PM
Did you run the .bat file?
08-12-2024 12:09 PM
Anyone pass the CTD? I'm shocked I got 18% on what was a fully functioning test when I submitted it...
