02-21-2025 04:04 AM
Hi
I got a type definition for a cluster that contain some path types.
In these path types I have set a default value
The I have a VI that I load into a LV pass/fail step. This VI has a input like Cluster step type.
How do I get the default values fro the Type def. to show in the step parameters?
Thanks in advance
Bjarne
02-21-2025 04:12 AM
Have you configured the Cluster Passing in your TestStand TypeDef?
02-21-2025 04:19 AM
Like this?
No difference
02-21-2025 04:33 AM
Guess you set this for all cluster members, right?
This is the "Synchronization" between the LabVIEW and the TestStand TypeDef
If that doesn't do the job... I am out of idea for the moment.
Though you could try to cresate a new step of this type and assign the VI again. Just in case we are seeing some kind of refresh issues here
02-21-2025 04:41 AM
Yes I did, but thanks anyway 😉
