01-24-2018 03:40 PM
Hi guys,
i create a custom step type, i.e. as copy of let's say numeric limit test (labview adapter). I add all of my variables, and i select a pre or post step vi to execute -> save etc. - so far so good.
Now when i select this custom step type and drop it in a sequence, i still have to explicit select a module (vi), which i want to execute? How i can predefine/set a default vi path (relative path in a default search directory) in the module tab? Is there a hidden ini or do i need to set a property?
My target is to hide the module tab and have the step ready as it is. My work-around currently is to insert the step in a sequence first, setup the module and afterwords drop it as a template in the template window.
I can hardly imagine that this is the best practise to this point.
I would highly appriciate if anyone could enlighten me.
Thanks much in advance and BR
Chris
Solved! Go to Solution.
01-26-2018 01:30 AM - edited 01-26-2018 01:37 AM
Hello weigsvader,
my trick is to set the custom step to non adapter and my code run as pre or post substep.
Hope it helps
01-26-2018 10:54 AM
Thanks mate,
so easy and so undocumented....
