NI TestStand
Determine if parameter exists
I am trying to programatically Enable and Disable database logging. Database is set to disable from Configure>Result Processing..., I write to Parameters.ModelPluginConfiguration.Plugins[1].PluginSpecific.Options.DisableDatabaseLogging value of False. This does not enables database and nothing gets comitted. All this customization is done in PreUUT.
Also need to have a precondition to find if a Parameter exists.
PropertyExists("Parameters.ModelPluginConfiguration.Plugins[Locals.DatabaseIndex].PluginSpecific.Options.DisableDatabaseLogging")
But the above always returns False. Need to receive True when Locals.DatabaseIndex is set to 1 as that is the location of Database under Configure>>ResultProcessing.
Thanks.
CLD
(4,444 Views)
Your lookup string is wrong. It has to look like this:
PropertyExists("Parameters.ModelPluginConfiguration.Plugins["+Str(Locals.DatabaseIndex)+"].PluginSpecific.Options.DisableDatabaseLogging")
hope this helps,
Norbert
Norbert
Expert: Geometry
(4,293 Views)
