NI TestStand
Goto Location Feature in the sequence analyzer
The working VI is attached.
By the way, no escape needed in the lookup string for LabVIEW.
George Zou
Message 11 of 14
(133 Views)
The VI works, but only goto the Properties tab.
How to show the Module tab?
George Zou
Message 12 of 14
(102 Views)
The general implementation in the sequence editor is that if the lookup string can resolve to a specific tab it will, but if not it goes to the Properties tab. I would hope that this also applies to the module properties under the Step.TS.SData, like Step.TS.SData.ViCall.VIPath.
What lookup string did you use that went to the Properties tab instead of the Module tab?
Scott Richardson
https://testeract.com
Message 13 of 14
(91 Views)
I use step name as lookup string.
BTW, I've already fixed the error.
George Zou
Message 14 of 14
(87 Views)
