NI TestStand
How can I choose display a step or not when sequnce running
    As customer requirement,I want to find a method to make a function: choose display a step when sequnce running. Now I only can choose trancing enable to control all sequnce dispaly or not when running, i want to find a fuction to control single step .thanks
Sonic
Sonic
Diffrent Strokes for Different Folks
(3,406 Views)
Hi Sonic,
I'm not entirely sure if I understand your requirements, but if you want to selectively control the tracing for a subsection of your sequence you could try using the TestStand API to enable/disable the tracing, eg.
ActiveX Action: Set IEngine{Runstate.Engine}.TracingEnabled(True)
[Steps to trace through]
ActiveX Action: Set IEngine{Runstate.Engine}.TracingEnabled(False)
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
(3,127 Views)
