NI TestStand
How can I get store procedure output
I have a store procedure that update values into an sql server database. The store procedure return a table with the values that have been updated. In a TestStand's sequence, how can I get  the output values of a store procedure ?
Thanks !
(2,125 Views)
I was able to make it works thanks !
(2,008 Views)
Accepted by topic author MarcHetuIntelia
Maybe this will help someone...
I only needed to add another data operation, with the right parameter, after executing my store procedure.
I store the store procedure's result into a variable of the same type.
(2,005 Views)
