How can I terminate my sequence when DI signal changed?
Hello, I have a problem that  I want to stop my sequence by DI signal changed.
(3,009 Views)
Hi, you can test the DI signal in vi using a while structure in another thread while main sequence is running. Then you can make use of an if statement to determine whether to get on running the sequence by the value of the vi.
(2,992 Views)
Accepted by topic author vista
Good idea
(2,978 Views)
