NI TestStand
How do you access station global teststand variables from your labwindows/CVI code?
The same way you Set and Get from Locals or FileGlobals.
The snippit of code below sets a StationGlobals variable called "NumericValue" to some random number:
tsErrChk(TS_PropertySetValNumber(seqContextCVI, &errorInfo, "StationGlobals.NumericValue", 0, (10 * rand()) / RAND_MAX));
Hope this helps
Ray Farmer
Regards
Ray Farmer
(4,430 Views)
Greetings,
How do i get the seqContextCVI or the Object handle. I am trying to read teststand station global variable from CVI.
deen..
(4,155 Views)
It depends what version of TestStand your are using, If its version 3.x or greater then just pass it as a parameter to you function.
Check out the Using the LabWindows/CVI with TestStand manual. Appendix B -4 is useful.
If its lower, one of the many examples in the TestStand examples folder should help
Regards
Ray Farmer
Regards
Ray Farmer
(4,152 Views)
