NI TestStand
How to access the columns of measurement, low limit, ... in the report in my sequence
Hi everyone,
I created a little testsequence of a HDD-check as you can see:
Now i was just wondering how to access the columns of measurement, low limit and high limit in the upper box, so that i only need one box for this sequence and don't "waste" so much place on my report.
The lower box is created with the "Numeric Limit Test"-function.
Is there any setting in my sequence, where i can access these things?
(671 Views)
Accepted by to0bi
Hi Tobi,
no possibility to configure this in your sequence or step settings.
The graphical representation (rows an coloums you are referring to) are created by using a stylesheet on the raw xml data, which is actually created.
You can modify the stylesheets though.
https://www.ni.com/docs/en-US/bundle/teststand/page/generating-and-customizing-teststand-reports.htm... is a good starting point
(611 Views)
