NI TestStand
How to add a result to the report when the subsequence call is set to result recording disabled
Hi All,
im trying to figure out a way to add a result to my report when the result occurs in a subsequence that has result recording disabled. I tried to set the step to result recording enabled however this did not work. Any thoughts or input would be appreciated
(782 Views)
What version of TestStand are you using.  You should be able to use this setting:
and it should override the sequence setting.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(736 Views)
