How to change flow properties run mode at runtime ?
How can I change flow properties run mode from e.g. normal to skip at runtime ?
I would like to execute my sequence in different measurement instrument setups and running of all sub-sequencies is not possible in certain setups.
I use TestStand 3.5.
regards,
Petri
(3,434 Views)
Maybe you could use the preconditions property on the subsequence calls, depending on the setup condition.
It's easier than changing the flow property at runtime.
If the precondition is ok, the step is executed.
If the precondition is ko, the step is skipped.
Bruno
(3,431 Views)
Thanks, I should go for that if I don't find solution to change the run mode.
In shipped OI, operator has capability to change the run mode in edit time. Benefit, I see, changing the run mode in run time forces the running of sequence to a certain known procedure.
(3,429 Views)
I agree with bruno_p but if you what to change the run mode use the TS API method Step.SetRunModeEx()
SetRunModeEx Method
Syntax
Step.SetRunModeEx ( newRunMode, [executionParam])
Purpose
Sets the run mode of a step.
Remarks
You can set the run mode either for the sequence file or for a particular execution. If you pass an Execution object for the executionParam parameter, the run mode change only applies to that execution and is lost when the execution is destroyed. If you do not pass an Execution object, the run mode change effects all current and future executions and is saved when you save the sequence file.
Parameters
newRunMode As String
[In] The RunModes constants define the valid values for this parameter.
executionParam As Variant
[In] [Optional] If you want to set the run mode for a particular execution only, pass a reference to an Execution object.
If you are useing TS4.1 then you can perform TS API calls in expressions therefore you could put your expression in the Step's Pre-Expression or even in the pre-condition.
Hope this helps
Regards
Ray Farmer
Message Edited by Ray Farmer on 08-28-2008 12:22 PM
Regards
Ray Farmer
(3,423 Views)
Thanks for quick response! I can now evaluate the best solution for me.
regards,
Petri
(3,416 Views)
