NI TestStand
How to eliminate an instance of "entering a sequence call" from the teststand report
I am using TestStand 4.2 and I am using a long sequence with several sub-sequences.  In these subsequences I am getting test results that I would like to place in the TestStand report.  Currently, in order to do this I have to check the "Record Result" option in the "Run Options" of the sequence call properties which displays an "Entering sequence call" mark on the report.  Is there any way that I can get rid of this marker and still record information from the sub sequence?
Message 1 of 14
(3,725 Views)
Results are stored in the resultlist then the resultlist is parsed as a string in the process model, you can delete the subsequenceCall from that string, you just have to add a step before logging the results to file in the associated process model callback (use the search and replace function available in a statement step type).
Rodéric L
Certified LabVIEW Architect
Message 2 of 14
(3,723 Views)
Can you explain a little more?
Message 3 of 14
(3,720 Views)
Is this in the SequentialModel process model?
Message 4 of 14
(3,704 Views)
Yes, I was indeed refering to the Sequential Process Model
Rodéric L
Message 5 of 14
(3,703 Views)
I am in the process model currently, but I am not able to find the point which you are referring to.
Message 6 of 14
(3,701 Views)
The processModel calls subsequences you have to look into it
Rodéric L
Message 7 of 14
(3,699 Views)
But which callback goes to callbacks of "sequence calls"?
Message 8 of 14
(3,695 Views)
You should have a look a these documents:
http://digital.ni.com/manuals.nsf/websearch/2B14FB1CD4FF25CA862577AE00554FC7
http://zone.ni.com/devzone/cda/tut/p/id/7958
Rodéric L
Message 9 of 14
(3,693 Views)
I believe I understand better now.  I should go to the "edit->sequence file callbacks".  I am confused as to which callback to effect.
Message 10 of 14
(3,688 Views)
