12-18-2024 12:14 PM
In my current TS setup, if Single Pass (Ctl+F5) it test one UUT, it generate one html report and stop. If Test UUTs (F5), it will keep appending the result on same one html report until stop. How to setup/configure TS so it will generate report for each UUT in the Test UUTs mode?
I searched in configure-> result processing and station option but cannot find it. Please help and thank you!
12-19-2024 12:02 AM
You've been looking at the right place 😉
12-19-2024 01:19 AM
That is exactly what I am looking for !
The reason I missed it because there is no that option when I am always thinking use "Specify Report File Path by Expression"🤣 but never try the other dropdown options
