06-05-2017 10:32 PM
I am in the development phase of a test sequence and the limits for my tests which are numeric limit tests are not fully locked down. Is there a way I can disable limit checking so that I can run multiple sequence runs to collect data to use for actually locking down the limits? Thanks!
06-06-2017 03:49 AM
There are multiple options
Options 1-4 require the numeric limit step itself to be modified. If multiple steps are affected, a tool using the TS API might help to ease the overhead. Esp. the overhead required to turn settings back...
06-06-2017 06:01 AM
Rethinking the request, i recommend you to do the following:
Use a property loader.
Export your current settings to a file using import/export tool. Create a copy (simply for 'security' reasons) and then modify the file by replacing the comparison type of all numeric limit steps by "LOG" (no comparison).
Import the modified limit file and run the sequence. Unless you save the modified sequence, you don't need to revert anything. If you want to save the file, you should revert the comparison type settings by importing the default configuration using the backup file.
