04-25-2007 12:34 PM
04-26-2007 12:54 PM
04-27-2007 03:36 AM
Hi Scott,
Thanks for your reply - it's a shame that there's no plans on the horizon to let TestStand recognise LabVIEW classes - I guess it just means being careful with the naming of vi's within classes if you're going to use them with TestStand i.e so that you don't get any kind of name duplication, but that's not a huge issue.
Thanks again for you response,
05-08-2007 06:21 PM
When flattening / unflattening an class instance like proposed above, do we loose any informaton that can prevent dynamic dispatching functions?
For example, a factory VI creates a CDerivedClass instance and flatten it to string such that TestStand can store it. TestStand then call an other VI (say a test algorithm) with this string as input parameter. The test algo VI "unflatten" the string to a CBaseClass instance. The algo VI calls a dynamic dispatch VI. Which dynamic VI gets called ? The one in the CBaseClass or the one in CDerivedClass.
dofr
05-16-2007 03:42 PM
dofr,
>When flattening / unflattening an class instance like proposed above, do we loose any informaton that can prevent dynamic >dispatching functions?
No, flattening does not lose information as LabVIEW classes are a by value data type.
>For example, a factory VI creates a CDerivedClass instance and flatten it to string such that TestStand can store it. TestStand then >call an other VI (say a test algorithm) with this string as input parameter. The test algo VI "unflatten" the string to a CBaseClass >instance. The algo VI calls a dynamic dispatch VI. Which dynamic VI gets called ? The one in the CBaseClass or the one in >CDerivedClass.
I coded up this example and the derived class's dynamic VI still gets called. There are some possibile ways you could get into trouble: If there are no instances of the derived class in memory LabVIEW may unload the VIs for the derived class. If you are storing refnums in your class there is the potential that the refnum could be closed while the class is flattened. If this happens the class will still unflattened w/o an error but the refnum wouldn't be valid. These problems occur with dynamic loading/unloading, if you load at the start of the execution and unload when the execution is finished you generally shouldn't see these problems.
-Rick Francis
05-23-2007 09:29 AM
Thank you, especially for the warning on the dynamic loading / unloading issue !
dofr
05-18-2015 03:36 PM
I am having a similar issue with LabVIEW 2011 SP1 and TestSTand 2010 SP1. This ATE uses vi's that are member's of class libraries, and the behavior I am seeing is sometimes when you open the vi's from within TestStand sequence editor, sometimes the vi will open up broken, and cite a myriad of issues with DAQmx drivers, canned LabVIEW function vi's, and of course membership issues for vi's claiming to be part of classes but the class reports that it isn't. Now these are working vi's that have no problems anywhere in their heirarchy, but yet open up broken. However, if you close the vi, and then refresh the VI prototype, this same vi will now up just fine with no errors.
Earlier in this discussion I read that TestStand is not compatible with LVOOP vi's, but I believe the problem goes deeper, can anyone better explain what may be occurring in this situation?
06-02-2015 03:17 PM
i have teststand 2014 and labview 2014 and they run pretty good with classes calling directly from teststand
06-02-2015 03:35 PM
It would not suprise me if the issue i am seeing was solved with later versions. Unfortunately, I am stuck at this version because of a driver incompatability with NI-FGEN.
I'm just trying to gain a better understanding of what may be causing the behavior, then maybe I can come up with a work around that won't force me to have recode the entire ATE.
Thanks.
