01-16-2024 09:34 AM
Hello all,
I'm starting to do some Test Stand sequences, and I'm having a Fatal Error that is always forcing me to close the program. This error always happens in the first run and I just can avoid it by deactivate and activate one option in the adapters configurations tab.
The error that I'm having is the next one -> "labviewv.lib was unable to locate a suitable location to resolve "MGApp". This may happen when too many instances of labview have been loaded into the same process."
Can someone help me to correct this error?
08-28-2024 09:07 AM
did you ever solve this issue.
11-14-2024 10:00 AM
Did you ever solve this issue? I am receiving the same error.
I have tried uninstalling and reinstalling Labview Runtime. Task manager shows only one instance of the software I am using so I am unsure what the issue is.
11-14-2024 10:22 AM
Yes, it was not a LabView issue but a software issue.
01-07-2025 08:09 AM
Sorry, I didn't understand if you were able to correct the error and if so, how did you do it?
01-07-2025 08:20 AM
The software supplied to me that uses LabView was outdated. Later version of software solved the issue
01-07-2025 09:02 AM
donde puedo escontrar esta nueva version del software?, que por ahora encuentro nada mas la antigua, muchas gracias
