NI TestStand
NI 9238 minimum voltage output
Hello
I am studying ISO standard 9869, focused on measuring the heat transferred through the walls of a building.
I am recording the heat-flux via a transducer and the NI 9238 is the compatible datalogger.
this standard gives you a methodology on how to quantify the uncertainty budget. From the NI 9238 datasheet I am not sure which is the correct value that corresponds to ISO requirement as minimum output provided by DL expressed in mV. The datasheet instead provides you the minimum voltage input +/- 0.496 V. This is not the value I am searching for.
Can you help in retrieving this minimum output of the DL? I am guessing the minimum is 0 from the interval given above. I don't have competencies in electrical field.
Regards
LC
(502 Views)
Duplicated with Minimum output in Volt for NI 9238
Control Lead | Intelline Inc
(484 Views)
