12-31-2014 12:22 PM
I am using a StepType our Company developed which is used to get information on available access points our portable router can see. After I send a status command the device will send a long list of access points (see example below). How do I parse this output to get the RSSI for a particular SSID. For example in the sample below how would I return the value of RSSI, -63dBm for SSID WKRP1? Your thoughts on how to tackle this problem. Thanks.
BSS 0:
SSID: \x00
BSSID: 00:1c:b1:88:b9:80
Channel: 1
RSSI: -72 dBm
bssType: Infrastructure
Security: wep-on
BSS 1:
SSID: WKRP1
BSSID: 00:0a:b8:7f:85:10
Channel: 4
RSSI: -63 dBm
Security: wpa-psk-tkip
sdc#
12-31-2014 12:38 PM
Personally, I would pass the entire string into a VI and pase it in LabVIEW. You can then use Regular Expressions or simple searches to get the information you want.
01-02-2015 01:02 AM
Can it be done without Labview in particular from Teststand? If so, how?
01-03-2015 04:31 AM
Hi Tony,
It can be done without LV but i feel its always easy to do in LV or any C based language.But if the requirement is minor and can be easily done through TestStand then its fine avoiding a vi or a dll.
I am attaching a example sequence which gives RSSI value from your example text.
This is what i did :
use split function to split all values into a string array.
Looked for a split string which contains RSSI
Took the next string which had RSSI value and converted it to number using val function.
If the text of interest is always in a fixed position then you can use functions like mid or left to grep the required text of interest.
Then use function like val( str) which converts this to a number.
Hope this helps.
Ravi
