09-13-2022 10:32 AM
With Test Stand 2017 and above, you can read and write excel files.
Can I programmatically convert an excel file to pdf in Test Stand? If not, what do you recommend?
09-13-2022 12:18 PM
By excel file, do you mean CSV?
CSV files are not Excel files but rather supported by Excel. Primarily Excel spreadsheet files end with xls or xlsx extension.
09-13-2022 12:58 PM
Very good question!
Ideally, I think a .xlsx file because it has the advantage of containing formatting information. See attached file which only has a single worksheet.
I was able to convert this file manually to a pdf with the Excel "Save As" function and that worked flawlessly (also attached).
