Read Custom Command Line Arguments When Running Sequence
I would like to be able to run a sequence file and have it accept a custom command line argument. For example I would like to run "TestSequence.seq" with the string "2710" as an argument to the sequence file (when I run via command line), which will be saved in a sequence local and used as an input to one of my VIs in the sequence file. Can anybody help me with this?
I have tried to capture the command line argument with the ActiveX module using RunState.Engine.GetInternalOption(InternalOption_ApplicationManager) & property CommandLineArguments
but I get an error popup saying the argument is not recognized.
Any help is appreciated.
(3,250 Views)
Accepted by topic author jkerrigan12
I think you can only do this inside of a UI that you have the source code for.  See this: https://zone.ni.com/reference/en-XX/help/370052W-01/tsuiref/reftopics/applicationmgr_processusercomm...
Since you don't have the source code for the sequence editor you cannot trigger that event and therefore cannot suppress the error.
jigg
CTA, CLA
testeract.com
(3,229 Views)
(3,209 Views)
Ok, I will incorporate this into my own teststand GUI.
Although it would be nice to have this option from the shipping version of teststand!
(3,199 Views)
There is a simple workaround to use custom command line arguments even for TestStand sequence editor. Just use /enableFeatures argument and specify your own "features to enable" separated by a semicolon.
e.g.
"%TestStand64%\Bin\SeqEdit.exe" /runEntryPoint "Single Pass" "<sequence_path>\test.seq" /enableFeatures param1_name;"param1 value";"param2 name";param_value
TestStand ignores unrecognized features and doesn't show error popup.
(218 Views)
