05-17-2022 10:29 AM
I am using Numeric Limit Test Step.
In the post expression I have a local variable PSVoltStatus to save the Step.Result.Status.
I see that Step.Result.Status has "Passed" status but Locals.PSVoltStatus always stores "Running" status.
How do I save Step.Result.Status status of "Passed"/"Failed"/"Skipped" in Locals.PSVoltStatus variable?
Thanks!!
Solved! Go to Solution.
05-18-2022 01:59 AM
Hi Ivrat,
thats pretty clear, when looking at the step exection (see help.)
you will see that PostExpression(19) is before StatusExpression(20)
on 19 will get "Running"
as workaround you may place it in user defined PostAction(32).
use the brackets for that like: { Locals.PSVoltStatus=Step.Result.Status },True
Best Regards
Juergen
