NI TestStand
Step.SwitchExecEnabled does not work as expected
I would like to dynamically set the "Enable Switching" checkbox in the Switching properties of a step.  I thought that setting the Step.SwitchExecEnabled variable to False in a pre-expression would disable switching, but it doesn't.  I did find that if I uncheck "Enable Switching" and set Step.SwitchExecEnabled to True, the second time I execute the step, switching will be enabled.  So it seems that the issue may be in the execution order between the pre-expression and the switching.
The reason I want to dynamically change the setting is that the same software must run on systems that may or may not have switching hardware.  I cannot use a precondition because I still want the step to execute.  I just want to skip the switching in some cases.  One workaround is to put the switching in a separate step, but there are many steps so I would like to avoid that if possible.
I'm using TS 2010.
(2,918 Views)
The only thing that executes before the switching is the precondition. You could change the switching setting in the precondition as follows:
Step.SwitchExecEnabled = StationGlobals.SwitchingEnabled, True
The ", True" at the end of the expression ensures that the preconditions still evaluates to True so that the step still executes. In a compound expression like this, the result of the combined expression is the result of the last expression.
Hope this helps,
-Doug
(2,902 Views)
