07-04-2022 05:25 AM
Goodmorning,
in a TS sequence i have 3 sequence a, b and c. a calls b which calls c. c is configured to run in a new thread and inside as some statement and a labview step which call the vi here attached. The vi starts polling the value of a fileglobal Boolean and if it is true it star the operation and compute some things. In the b sequence there is the wait thread step. The problem is that when I start the execution it arrives to the vi step but it always stays there, the thread is never close and I don’t understand if it is because the vi never catches the true value of the Boolean or if it is TS that never close that thread.
I have observed and tried all type of suggestion on paper and now ask help to you community for solving the matter
For sake of completeness, I have attached also the sequence. The vi step is in SCT measure sequence.
I save the files with both versions 14.0 and 21.0.
Thank you for the attention!
Best Regards,
Zuc
07-05-2022 07:40 AM
Hello Zuc,
I tried looking at your files, but I only have LabVIEW 2020 and I could not open any version of the SCT_Thread.vi because both copies of it are saved in LabVIEW 21.
Generally judging from your sequence I think we can eliminate sequence a from the equation.
Since you say the VI never finishes, obviously the calling Teststand step never finishes either, thus sequence c will not complete and the Thread won't come back.
The next step should be to debug inside the SCT_Thread.vi why it does not finish executing.
Maybe the lookup string for the boolean is incorrect? Hard to help here without being able to open the VI.
Stefan
