NI TestStand
Test Stand sequence merge in Git
We are using Test Stand for creating testing sequencies, and GIT for versioning.
We would like to introduce some collaborative work in our team and we want to find a way to merge the *.seq files into the branch. We also want to know if we can compare the modifications between previous versions of the sequence.
Do you know if there is a plugin, or something, to help us?
We are using now GitDesktop as application for GIT. We are also open to use other tools if necessary.
Thank you in advance.
Aurelian
(201 Views)
Yes, there is a tool which gets installed along TestStand.
Try googling  „TestStand Diff Merge Utility“
(160 Views)
Thank you Oil_Wachno for your answer.
I know about that software and it is useful, but my question was if there is a plugin related to Git (GitDesktop app) in order to merge the files during a commit or to compare with previous version.
(153 Views)
Sorry for not reading your message properly.
so I guess using the DiffMergeTool from the CLI wouldn’t be a solution….
(137 Views)
I've done it manually. Check out the old version and name it sequence_old.seq and run the NI diff tool on it. I make notes in a text editor and then use those notes in the commit message. Sorry, not exactly seamless...
(132 Views)
Thank you all for your answers.
This part with the notes is a good point. I will take it into consideration.
I will keep this open, maybe there are also other ideas, or there is a clear solution for this topic.
(86 Views)
