NI TestStand
TestStand Project Folder Structure
Hi to all
Is there a Guideline or best practice for the Folder structure for a TestStand Project.
I have a Project with a lot of Sub-Sequences and external Libraries and I don't know whats the best way to organize them.
What is your best approach?
Best regards
(399 Views)
Generally speaking…. Your main sequence file on toplevel, all dependencies in folder underneath.
This also leads to a very lean search directory structure
At least that’s what I recommend
are you using a TestStand Workspace?
(379 Views)
Accepted by topic author python007
Sometling like below works for me:
TopLevelSequelce.seq
subsequences\..\subsequence.seq
bin\mynice.dll
config\
key is to have all referenced as relative paths so when You deploy/move folder all works.
(369 Views)
Thanks for your answers
For me it is not clear where to place the code Modules for the subsequnces and how to deal with it when you have a code Modules used in more than one subsequnce?
Best regards
(351 Views)
I tend to put most of my library folders on the same file hierarchy level.
If they refer to each other, they only need to "jump up a folder" and "jump in" the appropriate other.
BTW.... using a TestStand Workspace can also help.
(344 Views)
Thanks a lot for your tips. In my next Project I will try to implement your tips!
Best regards
(280 Views)
