Teststand 2014 freezing when pressing "module"
Well after reinstalling TestStand still got the same issue, i think it's something wrong with the LabView Adapter. I don't know how to uninstall it.
Message 11 of 18
(175 Views)
The LabVIEW Adapter is part of TestStand which manages the LabVIEW Calls via ActiveX,
You could try repairing LabVIEW as well
Message 12 of 18
(166 Views)
Hello, i uninstall labview and reinstall it, still no hope. same problem
Message 13 of 18
(152 Views)
Clutching at straws....
Can you try the following:
1.) Close LV & TS
2.) Navigate to C:\ProgramData\National Instruments\<TSVersion>\Cfg
3.) Rename Adapters.cfg to something else
4.) Start TestStand
5.) Check again..
This is in case the repair / re-install hasn't removed the adater config properly.... AFAIK TestStand should recreate this file with default values.
Nevertheless.... if you are 100% sure this behaviour is directly linked to the execution of this Python script, you should check its' code!
Message 14 of 18
(143 Views)
Sorry but i don't have Adapters.cfg
Message 15 of 18
(136 Views)
Just saw, that there was a change in config directories when updating from 2014 to 2016...
Is there no adapters.cfg in that particular folder, or isn't there any on your computer?
Message 16 of 18
(132 Views)
There is no adapters settings at all.
Message 17 of 18
(124 Views)
Something to try - Using admin command shell can you try to re-register LV by executing LabVIEW.exe /regserver from the folder in which LabVIEW is installed.
Couple of questions:
1. If you launch LV first and then try to edit a LV step. Does that work?
2. Are you launching the TS SeqEdit as the current user who is logged in or with some other user privilege?
Anand Jain
NI
Message 18 of 18
(100 Views)
