08-18-2023 10:50 AM - edited 08-18-2023 11:25 AM
Getting these errors at runtime. Tried changing to "Load Dynamically" but a different error is thrown.
LabView 2020 is installed, as is NXG and LabView 2020 Runtime.
08-18-2023 11:25 AM
There are many steps you can try. Check out the knowledgebase articles.
Error -17600 Failed to Load a Required Step's Associated Module in TestStand
Error -17600 in TestStand Using the LabVIEW Run-Time Engine
