NI TestStand
Teststand fail step
i have some steps and i need to test them all, which means even some steps failed, i had to go on all steps test.
Teststand has some function to know which is the first failed step?
i want to use this information to popup the message for operator.
Teststand: 2017 or later
(495 Views)
Hello Sir i am teststand developer how can i help you?
CLA
(476 Views)
  1. Add a FileGlobals variable Boolean called FirstStepFailed
  2. Add a FileGlobals variable String called FirstStepFailedStepName
  3. Put a SequenceFilePostStepFailure callback in your sequence
  4. In the SequenceFilePostStepFailure sequence, add a condition if FileGlobals.FirstStepFailed is false then set FileGlobals.FirstStepFailed to true and set  FileGlobals.FirstStepFailedStepName to Parameters.Step.Name
  5. In Cleanup group, add a Message Popup with a Message Expression "The First Failed Step was: " + FileGlobals.FirstStepFailedStepName
(462 Views)
hello ee-jallen,
appreciate for your feedback, i still don't know how you locate the first fail step, can you show me a simple sequence for this?
best regards!
(448 Views)
