NI TestStand
Upload a file to a hardware with ethernet connection using teststand
Hi
I am totally new to TestStand, and I have been given a task, where among other things I need to upload a file (software image) using teststand to some hardware that is produced by our company, the hardware has an ethernet connection.
My question is how to create a step in the teststand that establishes a connection to the hardware IP address?
Then I need to make it choose a file from a specific directory, see please the attached pictures..
I hope I made my question clear!!
Thanks for taking the time to read and give some guide in this regard.
(682 Views)
You need to create a VI to do it ( or a DLL ).
This VI will connect to the hardware and upload the file.
From TestStand you need to call this VI.
It can be a VI or function in DLL.
You can add parameters to the functions...basically file path and hardware IP if required or else you can fix it in your code.
Ravi
(643 Views)
