10-30-2014 09:59 PM
I have two VIs, one acquiring waveform data, the other using that waveform data to calculate some characteristics.
When I use a waveform cluster as output of the first and input of the second VI, the first VI is loaded correctly into TestStand; for the second VI I get the error that the parameters do not match the controls of the VI. Actually, no parameters are shown at all in TestStand 2012 and the prototype is never updated.
When I change the signal representation to an X and Y value array, then it works.
What can be the problem here?
Peter
10-31-2014 03:35 AM
Peter,
it sounds as if this issue is connected to this issue you have. So does this issue occur on the same PC?
Did you already double check with another PC? What about a repair install?
Norbert
10-31-2014 09:46 AM
Yes, this was on the same PC. I will double-check as soon as I have the opportunity (currently traveling).
Thank you for confirming the connection of the two issues; so I am searching only for a single problem.
Regards
Peter
11-03-2014 05:46 AM
Hi Peter,
if reparing does not work, a short example would be very helpful for finding the issue.
Best Regards, Fabian
