NI TestStand
When will ActiveX/COM Teststand API be deprecated?
ActiveX is a deprecated software framework created by Microsoft in 1996.
Teststand API is built on top of it.
When will NI delete this obsolete trash tech?
thanks
(283 Views)
TestStand has a gRPC API (see github). You could use this along with .NET. Do check this out.
We are also currently working on creating web based UI controls as an alternative for ActiveX UI controls.
(255 Views)
You are a S-level hero
thanks
(245 Views)
