array out parameter from labview
i want to join UInt8 arrays (MSB/LSB) to a UInt16 array.
If i run this in LabView is no Problem.
But when i call from TestStand, there is no Out Parameter filled.
After i run the Teststep there are no Values in the Locals.MSBLSB Array. Is there any Parameter i had to set that LabView can write into the Locals.MSBLSB Array?
Regard,
René
(3,196 Views)
Accepted by renek
So what values have you got in the two arrays locals.lsb and locals.msb because if these are empty arrays then you will not get any output?
Regards
Ray Farmer
Regards
Ray Farmer
(3,189 Views)
i make a mistake. I look to the out Array after the Test is running. After i set a Breakpoint i see the Values during testing.Smiley Embarassed
Thanks for the answer
(3,187 Views)
