NI TestStand
calling a subsequence from an expression
Is it possible to call a subsequence in TestStand from an expression? I have a dialog action step and would like to call a subsequence from a it's pre-expression and then a different one from it's post- expression. This would save a ton of steps in TestStand. Otherwise I need two sequence call steps (one before the diaog step and one after). Thanks
(3,219 Views)
Why do you need to call sequences? What exactly are they doing? Have you considered creating a step type? Or perhaps a utility sequence that contains the steps you want to execute including the dialog step and the two sequence calls? I might be able to suggest a more straightforward alternative if you provide more details about what you are trying to do.
-Doug
(3,213 Views)
