08-17-2016 11:38 AM
I have a standard test stand solution like most of yours, a main sequence and many of sub-sequence.
When run single pass in debug mode. the 'single pass' window will show the current sequence or sub-sequence.
My question is I don't care the progress of sub-sequence, I care only the main sequence.
So any way to fix display only the main sequence in that window?
Thank you!
version: TestStand 2014 32bit
08-17-2016 03:57 PM - edited 08-17-2016 03:58 PM
Hello!
I think disabling tracing may help 🙂
I don't have TestStand in front of my eyes but as far as I remember:
If you change it your cursor will stay in main sequence.
Let me know if this helped!
mtwar
08-18-2016 03:59 AM
As suggested by mtwar, Disable Tracing the Possible option, but if you have a sub sequence which executes for a longer time then it seems like it hanged some where as the user wont be getting any feedback or response still the sub sequence completes its execution.
08-24-2016 07:06 PM
Yes, it is excetly what I'm looking for.
thank you!
