03-08-2012 03:45 PM
I was having issues installing my Custom Sequence editor on a new computer without any NI software installed. I created a new deployment that only installs the SeqEdit.exe, the msgbox.dll and the NI dll's for the System32 directory. The SeqEdit will not run after the Install and reboot. If I run the version selector, I can get the SeqEdit.exe to work. I am running TestStand 2010 SP1 and the TestStand Deployment Utility is from SP1.
Is there something missing in my deployment that forces the registration of the TestStand 2010 SP1 components? This originally happened on a computer that had the non-SP1 version of TestStand. If I run the installer on a computer with TestStand 2010 SP1 already installed, I do not have any issues.
In the Engine Options, I have selected the following:
(all) TestStand Components
All of the NI LabVIEW Run-time Engines.
Database and Property Loader Step Types
Code Templates
TestStand .NET Support (gray)
TestStand Sequence Editor
TestStand Sequence Analyzer
In the Drivers and Components:
LabView 2011 Run-Time Engine Non-English Support
All of the NI LabVIEW Run-TIme engines except 2009 (64-bit)
LabVIEW Run-Time Engine Web Server
LabWindows/CVI 2010 Run-Time Engine
NI LV Web Services Runtime
Custom Commands
Request Reboot After All Commands Execute is checked.
03-08-2012 04:14 PM
Take a look at this thread, you might be having the same issue.
03-08-2012 05:11 PM
This looks like a possible solution, however, there is not a TSDotNetUIControls.dll in the Bin folder for TestStand2010 SP1. The only DotNet files areTSDotNetSupport.dll and TSDotNetSupport.tlb
03-09-2012 02:08 PM
I was able to get this to run on a new machine. I had to manually copy the following files from my development PC to the Bin directory on the new computer:
TSDotNetSupport.dll
TSDotNetSupport.tlb
TSAnalyzer.Interop.dll
TSFileDiffer.Interop.dll
I then entered the following in the cmd window
C:\Windows\Microsoft.NET\Framework\v2.0.50727\RegAsm.exe /tlb "<TestStand>\Bin\TSDotNetSupport.dll
I will add this to my post installation batch file.
