NI TestStand
new python call teststand engine
I re-write my issue in new message.Thanks very much for altenbach's remindding.
I use python and teststand engine to customize solution.But I have some questions about it.
1,code as below:
tsEngine = win32com.client.Dispatch("TestStand.Engine.1")
print "TestStand %s.%s ready" % (tsEngine.MajorVersion, tsEngine.MinorVersion)
tsEngine.UIMessagePollingEnabled = True
sequencePath = os.path.join(cwd, 'MySequence.seq')
seqFile = tsEngine.GetSequenceFileEx(sequencePath)
execution = tsEngine.NewExecution(seqFile, "MainSequence", seqFile, False, 0)
execution.WaitForEndEx(60000)
execution = None
released = tsEngine.ReleaseSequenceFileEx(seqFile, 0x4)
seqFile = None
tsEngine.ShutDown(True)
tsEngine = None ## Execution freezes here
2,I need to use UImessage to get pass/fail result of "MySequence.seq".
So the first step,I set "tsEngine.UIMessagePollingEnabled = True".
But python print these error:
Traceback (most recent call last): File "D:\TS_solution\CallTestStand.py",
line 39, in released = tsEngine.ReleaseSequenceFileEx(seqFile, 0x4) File "",
line 3, in ReleaseSequenceFileEx pywintypes.com_error: (-2147352567, '\xb7\xa2\xc9\xfa\xd2\xe2\xcd\xe2\xa1\xa3', (0, u'TSAPI', u"Unable to unload sequence file 'MySequence.seq' because it is in use, possibly because it is executing.", None, 0, -17213), None)
3,I comment "tsEngine.UIMessagePollingEnabled = True",
then teststand pop-up warning windows,show as below:
References to PropertyObjects were not released properly.
Total number of objects: 53
Number of top-level objects: 13
Note: Some top-level objects may be included if they are referenced by an incorrectly released top-level object.
For example, an unreleased SequenceContext object references a SequenceFile object.
The following top-level objects were not released:
Executions [1 object(s) not released]
Type Definitions [2 object(s) not released]
Type Definition
#1: Name: CommonResults Type Definition
#2: Name: Error PropertyObjects
[6 object(s) not released] PropertyObject
#1: Type: ActiveX Reference Value: Nothing PropertyObject
#2: Type: ActiveX Reference Value: Nothing PropertyObject
#3: Type: Obj PropertyObject
#4: Type: Array of Containers PropertyObject
#5: Type: Array of Containers PropertyObject
#6: Type: Array of Containers And the following uncategorized objects:
UIMessage (TEMessage)
Report
EditArgs
4,How can I call Teststand API--UImessage class through Python?
Message 1 of 1
(4,616 Views)
