NI TestStand
"EditPathsInFilesDialog" is missing in TS4.1
The menu item EditPathsInFiles is not longer available in TS4.1
But it is still in the API!
So here is a solution to re-add this item:
Just go to Tools => Customize
Add a new sequence item like on the screenshot below.
This will execute the attached file "CallPathsInFilesDialog.seq"
(2,951 Views)
Accepted by topic author Greil
The menu item is still available, but it is hidden by default. To add the command to the sequence editor, right-click on a toolbar or menu and select Customize from the context menu. Click on the Commands tab. Right-click in the commands list and select Sort Commands Alphabetically from the context menu. Scroll down until you find the Edit Paths... item. Drag that item to a menu or a toolbar to make it available in the sequence editor.
(2,933 Views)
