12-11-2024 08:31 AM
When calling a LabWindows/CVI 2019-compiled .dll file from TestStand2019 or LabVIEW, I see the following error message:
This DLL requires the following DLLs which could not be found or loaded:
api-ms-win-core-libraryloader-l1-2-0.dll (Not Found)
api-ms-win-core-heap-l2-1-0.dll (Not Found)
api-ms-win-core-errorhandling-l1-1-2.dll (Not Found)
api-ms-win-gdi-internal-uap-l1-1-0.dll (Not Found)
api-ms-win-core-delayload-l1-1-1.dll (Not Found)
api-ms-win-core-delayload-l1-1-0.dll (Not Found)
api-ms-win-core-apiquery-l1-1-0.dll (Not Found)
api-ms-win-core-rtlsupport-l1-2-0.dll (Not Found)
api-ms-win-core-processthreads-l1-1-3.dll (Not Found)
api-ms-win-core-processthreads-l1-1-2.dll (Not Found)
api-ms-win-core-registry-l1-1-0.dll (Not Found)
api-ms-win-core-memory-l1-1-1.dll (Not Found)
api-ms-win-core-memory-l1-1-2.dll (Not Found)
api-ms-win-core-synch-l1-2-1.dll (Not Found)
api-ms-win-core-file-l1-2-2.dll (Not Found)
api-ms-win-core-file-l1-2-4.dll (Not Found)
api-ms-win-core-file-l1-2-1.dll (Not Found)
api-ms-win-core-io-l1-1-0.dll (Not Found)
api-ms-win-core-io-l1-1-1.dll (Not Found)
api-ms-win-core-job-l1-1-0.dll (Not Found)
api-ms-win-core-threadpool-legacy-l1-1-0.dll (Not Found)
api-ms-win-core-threadpool-private-l1-1-0.dll (Not Found)
api-ms-win-core-libraryloader-l1-2-3.dll (Not Found)
api-ms-win-core-libraryloader-l1-2-2.dll (Not Found)
api-ms-win-core-libraryloader-l1-2-1.dll (Not Found)
api-ms-win-core-libraryloader-l2-1-0.dll (Not Found)
api-ms-win-core-namedpipe-l1-2-2.dll (Not Found)
api-ms-win-core-namedpipe-l1-2-1.dll (Not Found)
api-ms-win-core-datetime-l1-1-1.dll (Not Found)
api-ms-win-core-datetime-l1-1-2.dll (Not Found)
api-ms-win-core-sysinfo-l1-2-1.dll (Not Found)
api-ms-win-core-sysinfo-l1-2-3.dll (Not Found)
api-ms-win-core-localization-private-l1-1-0.dll (Not Found)
api-ms-win-core-processsnapshot-l1-1-0.dll (Not Found)
api-ms-win-core-processenvironment-l1-2-0.dll (Not Found)
api-ms-win-core-debug-l1-1-1.dll (Not Found)
api-ms-win-core-errorhandling-l1-1-3.dll (Not Found)
api-ms-win-security-base-l1-1-0.dll (Not Found)
api-ms-win-security-base-l1-2-0.dll (Not Found)
api-ms-win-core-comm-l1-1-0.dll (Not Found)
api-ms-win-core-wow64-l1-1-1.dll (Not Found)
api-ms-win-core-wow64-l1-1-0.dll (Not Found)
api-ms-win-core-wow64-l1-1-3.dll (Not Found)
api-ms-win-core-realtime-l1-1-0.dll (Not Found)
api-ms-win-core-systemtopology-l1-1-1.dll (Not Found)
api-ms-win-core-systemtopology-l1-1-0.dll (Not Found)
api-ms-win-core-processtopology-l1-1-0.dll (Not Found)
api-ms-win-core-namespace-l1-1-0.dll (Not Found)
api-ms-win-core-file-l2-1-2.dll (Not Found)
api-ms-win-core-file-l2-1-1.dll (Not Found)
api-ms-win-core-file-l2-1-3.dll (Not Found)
api-ms-win-core-xstate-l2-1-0.dll (Not Found)
api-ms-win-core-xstate-l2-1-1.dll (Not Found)
api-ms-win-core-xstate-l2-1-2.dll (Not Found)
api-ms-win-core-localization-l2-1-0.dll (Not Found)
api-ms-win-core-normalization-l1-1-0.dll (Not Found)
api-ms-win-core-heap-obsolete-l1-1-0.dll (Not Found)
api-ms-win-core-fibers-l2-1-0.dll (Not Found)
api-ms-win-core-fibers-l2-1-1.dll (Not Found)
api-ms-win-core-sidebyside-l1-1-0.dll (Not Found)
api-ms-win-core-appcompat-l1-1-0.dll (Not Found)
api-ms-win-core-appcompat-l1-1-1.dll (Not Found)
api-ms-win-core-windowserrorreporting-l1-1-1.dll (Not Found)
api-ms-win-core-windowserrorreporting-l1-1-2.dll (Not Found)
api-ms-win-core-windowserrorreporting-l1-1-0.dll (Not Found)
api-ms-win-core-windowserrorreporting-l1-1-3.dll (Not Found)
api-ms-win-core-console-l1-2-1.dll (Not Found)
api-ms-win-core-console-l2-1-0.dll (Not Found)
api-ms-win-core-console-l2-2-0.dll (Not Found)
api-ms-win-core-console-l3-2-0.dll (Not Found)
api-ms-win-core-psapi-l1-1-0.dll (Not Found)
api-ms-win-core-psapi-ansi-l1-1-0.dll (Not Found)
api-ms-win-security-appcontainer-l1-1-0.dll (Not Found)
api-ms-win-core-threadpool-l1-2-0.dll (Not Found)
api-ms-win-core-string-obsolete-l1-1-0.dll (Not Found)
api-ms-win-core-kernel32-legacy-l1-1-0.dll (Not Found)
api-ms-win-core-winrt-error-l1-1-0.dll (Not Found)
api-ms-win-core-winrt-error-l1-1-1.dll (Not Found)
api-ms-win-core-registry-l1-1-1.dll (Not Found)
api-ms-win-security-activedirectoryclient-l1-1-0.dll (Not Found)
api-ms-win-shcore-taskpool-l1-1-0.dll (Not Found)
api-ms-win-mm-time-l1-1-0.dll (Not Found)
api-ms-win-core-stringansi-l1-1-0.dll (Not Found)
api-ms-win-core-privateprofile-l1-1-0.dll (Not Found)
api-ms-win-core-path-l1-1-0.dll (Not Found)
api-ms-win-core-shlwapi-legacy-l1-1-0.dll (Not Found)
api-ms-win-core-kernel32-private-l1-1-2.dll (Not Found)
api-ms-win-core-kernel32-private-l1-1-0.dll (Not Found)
api-ms-win-core-crt-l1-1-0.dll (Not Found)
api-ms-win-core-crt-l2-1-0.dll (Not Found)
api-ms-win-core-string-l2-1-0.dll (Not Found)
api-ms-win-core-memory-l1-1-3.dll (Not Found)
api-ms-win-core-atoms-l1-1-0.dll (Not Found)
api-ms-win-core-localization-obsolete-l1-2-0.dll (Not Found)
api-ms-win-core-kernel32-legacy-l1-1-1.dll (Not Found)
api-ms-win-core-appinit-l1-1-0.dll (Not Found)
api-ms-win-stateseparation-helpers-l1-1-0.dll (Not Found)
api-ms-win-core-quirks-l1-1-0.dll (Not Found)
api-ms-win-core-psm-key-l1-1-0.dll (Not Found)
api-ms-win-eventing-consumer-l1-1-0.dll (Not Found)
api-ms-win-eventing-consumer-l1-1-1.dll (Not Found)
api-ms-win-service-core-l1-1-0.dll (Not Found)
api-ms-win-service-core-l1-1-1.dll (Not Found)
api-ms-win-service-core-l1-1-2.dll (Not Found)
api-ms-win-service-management-l1-1-0.dll (Not Found)
api-ms-win-service-management-l2-1-0.dll (Not Found)
api-ms-win-service-private-l1-1-4.dll (Not Found)
api-ms-win-service-private-l1-1-2.dll (Not Found)
api-ms-win-service-private-l1-1-3.dll (Not Found)
api-ms-win-service-private-l1-1-0.dll (Not Found)
api-ms-win-service-winsvc-l1-1-0.dll (Not Found)
api-ms-win-security-base-private-l1-1-0.dll (Not Found)
api-ms-win-core-registry-l1-1-2.dll (Not Found)
api-ms-win-security-audit-l1-1-1.dll (Not Found)
api-ms-win-security-audit-l1-1-0.dll (Not Found)
api-ms-win-core-pcw-l1-1-0.dll (Not Found)
api-ms-win-core-string-l2-1-1.dll (Not Found)
api-ms-win-core-localization-l1-2-2.dll (Not Found)
api-ms-win-core-version-l1-1-0.dll (Not Found)
api-ms-win-eventing-classicprovider-l1-1-0.dll (Not Found)
api-ms-win-core-shlwapi-obsolete-l1-1-0.dll (Not Found)
api-ms-win-core-kernel32-legacy-l1-1-2.dll (Not Found)
api-ms-win-core-url-l1-1-0.dll (Not Found)
api-ms-win-core-registryuserspecific-l1-1-0.dll (Not Found)
api-ms-win-shell-shellcom-l1-1-0.dll (Not Found)
api-ms-win-core-job-l2-1-0.dll (Not Found)
api-ms-win-core-versionansi-l1-1-0.dll (Not Found)
api-ms-win-core-version-l1-1-1.dll (Not Found)
api-ms-win-core-versionansi-l1-1-1.dll (Not Found)
api-ms-win-core-version-private-l1-1-0.dll (Not Found)
How can I solve this issue?
