NI TestStand
some problems about TestStand UI after change PC
hello everyone,
I just bought a new PC, a Thinkbook14+. The screen resolution use default setting as below:
but in teststand, some icons are really small, and some of the positions overlap.
Is there any solutions? It looks and uses inconvenient.
Thanks in advance!
(1,078 Views)
Try the setting in All the Main Application Windows in LabVIEW Are Tiny. It works for all NI software.
(1,059 Views)
Obviously, you have changed the display scale and changed the system default font
Teststand software is not suitable for high-resolution screens (UI interface is C # Winform, using some DevExpress controls). For me, using the default font and resolution on a 32 inch 2K resolution screen and a 27 inch 4K resolution screen is normal (although some content may appear relatively small).
However, do not attempt to change the font and display ratio, as this may be the beginning of a disaster.
Try to restore them default? Or ask NI brothers to do high-resolution screen adaptation work?
(1,051 Views)
thank for your suggestion, it's solved.
(1,000 Views)
thank you, it's solved follow ZYOng's suggestion.
(995 Views)
