10-06-2009 03:14 AM
hi,
anyone knows how can i record a test running in labview 8.6 to be able to check the sequenced of the test later?
thanks
Solved! Go to Solution.
10-06-2009 09:06 AM
Are you talking about a TestStand sequence.
By default all Test step type have the record enabled so that a report is generated, providing its enabled in the Configuration | Report Options menu or overridden by the Callback sequence ReportOptions, when you execute a sequence via "Test UUTs" or "Single Pass" entry point.
But my guess is you are not talking about TestStand have a purely LabVIEW question, which case you need to repost to the LabVIEW forum.
Regards
Ray Farmer
