NI TestStand
trouble deploying TestStand
I have tried many suggestions and configurations but I still cant get my deployed TestStand to run in other PC. I kept getting "Unable to launch the 'LabVIEW .Application' ActiveX automation server. TestStand cannot find a LabVIEW Development System installed in this computer." My test sequence also uses custom process model. Below are the things that I have done:
1. Configured the LabVIEW adapter to use RTE and enable "Always Run VI in LabVIEW RTE" in the LabVIEW Advanced Settings under Module tab.
2. Added configuration .ini files that will be used, including TestExec.ini and TestStandModelModelOptions.ini in workspace.
3. Enable "Install TestStand Engine" and leave Engine Options/ Drivers and Components as default.
Below are my questions:
1. Since I am using custom process model, where should I save this .seq in?Is it in my working directory or TestStand components folder? Reason why I am asking this is because I tried both ways, the latter gave me
"Warning: This problem will cause an error when building a deployable image or an installer. The following file(s) were not found:
rfid_read_write.seq in step 'Reset Test Sequence', sequence 'MainSequence', sequence file 'C:\Program Files (x86)\National Instruments\TestStand 4.2.1\Components\Models\TestStandModels\SequentialModel_RFID.seq'"
Obviously rfid_read_write.seq has already been included and present.
2. Should I also include this custom process model .seq file in the workspace/deployment?
3. How to solve the unable to launch LabVIEW.Application issue?
Thanks.
Message 1 of 1
(4,051 Views)
