NI VeriStand Add-Ons Discussions
Behavior of the Veristand engine and inline model custom devices
I just want to report a dubious behavior of the veristand engine in case of an "Inline Model" custom device in the "Parrallel mode":
I notice that the number of PCL's iterations between the reception of inputs and the update of outputs, is impacted by the properties "Scalable" and "Faultable" of the channels:
With the two properties set to "False", the intputs and outputs are updated on the same iteration of PCL.
But if I set one property to "True" then the outputs are updated on the next iteration of PCL.
And if I set the two properties to "True" then the outputs are updated two iterations of PCL later !
This behavior induces a device control instability as the custom devices outputs are transfered too late.
The workaroud is of course to set the properties to false.
Nevertheless I also wonder if this working is the same for the other tasks like the models tasks ?
Message 1 of 1
(3,375 Views)
