These Python examples use the ASAM XIL API to read and write to channels, capture and save channel value data to an MDF4 file, and configure stimulus signals with a running NI VeriStand system. These scripts reference the Engine Demo example project.
These examples are based on the ASAM XIL C# Examples that are included in the NI VeriStand Help and have similar functionality to those examples.
NI VeriStand 2015 SP1 or compatible
Python 3.6 (32-bit)
Note: You must use 32-bit Python to interact with VeriStand.
To run in versions earlier than NI VeriStand 2018 update the NI VeriStand ASAM XIL Interface in each script for your version of the software. For example, in NI VeriStand 2016 you would want to set the interface to "NI VeriStand 2016 ASAM XIL Interface" and the version to "16.0.0". For NI VeriStand 2017, you would want to set the interface to "NI VeriStand 2017 ASAM XIL Interface" and the version to "17.0.0".
For NI VeriStand 2018, only the version number needs to be changed. The interface should be set to "NI VeriStand ASAM XIL Interface" and the version to "2018.0.0".
Accessing the NI VeriStand ASAM XIL Interface
C# Walkthrough: Using the Model Access Port to Read and Write Channel Values
C# Walkthrough: Configuring and Executing Stimulus Signals
C# Walkthrough: Capturing and Logging Channel Values
This is provided as open-source software. If it does not meet your exact specification, you are encouraged to modify the source code to meet your needs. It is not officially supported by National Instruments.
National Instruments does not support this code or guarantee its quality in any way. THIS EXAMPLE PROGRAM IS PROVIDED "AS IS" WITHOUT WARRANTY OF ANY KIND AND SUBJECT TO CERTAIN RESTRICTIONS AS MORE SPECIFICALLY SET FORTH IN NI.COM'S TERMS OF USE (http://ni.com/legal/termsofuse/unitedstates/us/).
It seems there is no available packages of ASAM.XIL and System in package and error as following . Could you so nice to tell me where I could download these packages as following?
What is your means Import necessary .NET constructs ?
# Import necessary .NET constructs
from System.Collections.Generic import Dictionary
from System.Collections.Generic import List
# Import functions from the reference assemblies in the directory above
import ASAM.XIL.Interfaces.Testbench
import ASAM.XIL.Implementation.TestbenchFactory.Testbench
from ASAM.XIL.Implementation.TestbenchFactory.Testbench import TestbenchFactory
