PXI
Cannot simulate PXI-8513
Hello, I tried to create a simulated PXI-8513 with MAX to test CAN BUS protocol but I can't see PXI-8513 card in MAX.
I installed NI-XNET 20.5 according to my environment compatibility (Labview 2017).
(102 Views)
NI-XNET devices cannot be simulated, unfortunately.
Control Lead | Intelline Inc
(73 Views)
Thanks for your answer.
How can I test a CAN BUS TX/RX without the hardware device? Can I do something like a loopback?
(53 Views)
No, you cannot test CAN communication using NI-XNET without actual hardware. You need actual hardware to do loopback.
(42 Views)
Is it possibile with NI-CAN ?
(32 Views)
NI-CAN does support virtual devices.
However, NI-CAN is obsolete and not recommended for new development. Although you can run the NI-CAN API on an NI-XNET device using a compatibility library, not all features are supported.
(21 Views)
