PXI
DAQmx 9.5 and Multiple PXI-6133s
I received a letter from NI informing me that the issue with multiple S series cards was fixed in 9.5, however, once I updated to 9.5.0 my triggering no longer works at all.
I have an PXI-1042 chassis with 3 PXI-6133 cards, 2 have their own triggers, the third is triggered by one of the other 2, the issue supposedly addressed by 9.5 was the pre-trigger data not getting captured by the device with the shared trigger (I saw this issue).
Now with no code changes and simply updating the DAQmx and recompiling my capture no longer works, master never triggers (times out) and slave triggers immediately (solo card not used as master works fine)
any clues as what is happening?  Oh using LabVIEW 2010 DS1 and Realtime 10.0.1 on the chassis
(3,660 Views)
Hi DogOnWood,
Would you be willing to post your code? Even if there is no problem with it, doing so may help us better understand the setup of your project. I am wondering what kind of line you are using as the input of the triggers. What are the settings for the master trigger? What is the overall goal of the project?
As a note, you could try resetting the 6133 cards by going into Measurement and Automation Explorer, right clicking on the card name under Devices and Interfaces, and selecting 'Reset Device.' This may not help, but it is good to try.
Nathan S.
(3,638 Views)
