07-15-2019 10:48 AM
I am working on an academic project. I am using myRIO 1900. i want to access my front panel remotely on web. I have followed
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P7YuSAK&l=de-DE
http://zone.ni.com/reference/en-XX/help/370622R-01/lvrthowto/remotepanels_rt_target/
links.
But, when I try to access on web I encounter error shown in browser.jgp file.
some other pictures are also attached.
If some one understand whats going wrong, Please figure out.
If there is any example for myRIO front panel remote access please share. Thank
07-17-2019 01:39 AM
07-17-2019 05:25 AM - edited 07-17-2019 05:29 AM
HI Emboar,
browser.jpg is attached here.
Also, I want to ask "Do mtRIO needs wifi Conection". if "yes" Which IP adress I should use.
IP Adress when Conneted through USB is 172.22.11.2 and when Connected over Wifi IP adress is Something like shown in "image.png" .
07-21-2019 08:29 PM
You want to have a connection via Wifi but it looks that the connection is established via 172.11.22.1.
The IP is used on USB over Ethernet, not Wifi.
I believe myRIO on your LabVIEW project is set to "172.11.22.1".
Why don't you change it to "172.16.21.217" and try it again.
11-22-2019 09:06 AM
Hello.
I have a similar problem. But I managed to connect to the RT device using the "connect to remote panel" function in Labview and also in Labview Run-time. But when I try to connect using the IE browser, I get a 404 error. http://192.168.0.101:8080/Main.html
Meantime i can easily connect to file browser of my RT device (myRIO-1900) via https https://192.168.0.101/files/ .and when i browse to html file manual i will recieve next error (ERROR.PNG)
HTTP port 8080.
